pulling out axle vs
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by vzhappywagon, May 1, 2008.
  1. vzhappywagon
    vzhappywagon New Member
    vz executive wagon
    hey people, left side rear axle solid diff having truoble pulling it out. pulled off rotor undid the four bolts, should it just pull out or does it need some hard whacks. also the handbrake shoes can they stay as they are or do they have to be taken off. we are getting a grinding noise taking left hand turns thinking the bearings are gone, got an axle from wreckers to replace. thanks
  2. hako
    hako Donating Member
    Toowoomba SE QLD
    VS11 BT1 V6
    Make sure the handbrake is off and then refit the brake disc (rotor) backwards with the nuts loose and use it as a slide hammer.
  3. hako
    Toowoomba SE QLD
    VS11 BT1 V6
  4. DannyboyDS
    DannyboyDS Just hand me the pliers.
    VS Berlina
    im just curious, but how do you go about refitting? will it just "slide" on in and then once everything is replaced it will stay?
    Iv'e never done the job before, but would like to know incase it ever comes up.
  5. hako
    Toowoomba SE QLD
    VS11 BT1 V6
    The 4 bolts hold a fairly heavy retaining plate which secures the bearing/axle in the diff housing. The bearing is pressed onto the shaft and then a retainer ring is pressed flush up against the bearing. This setup is more or less fail-proof.
  6. Not_An_Abba_Fan
    Not_An_Abba_Fan Exhaust Guru
    Bunbury, WA
    Strange Rover
    I think Dannyboy was asking about refitting the axle to the car.
    Yes, it just slides in, with a bit of effort. You need to wiggle it so it engages the diff gear, then push it in hard. If the retaining plate sits against the diff housing, it is all the way in. If it isn't, wiggle it in and out a little bit until it slides home. A bit like a virgin....
  7. vzhappywagon
    vz executive wagon
    thanks hako, just got back from work, i can picture exactly what your saying
  8. hako
    Toowoomba SE QLD
    VS11 BT1 V6
    Put it down to old-age, at least I answered the last part of his question: and then once everything is replaced it will stay?....:thumbsup:
