pulsing feeling at higher speed
Discussion in 'General' started by stocky, Nov 21, 2008.
  1. stocky
    stocky New Member
    img etting this weird feeling in the car when im cruising along. if im sitting on the freeway doing 80-100km/h, there is a kinda pulsing noise/vibration throughout the car every 1 second or so.
    i noticed it kinda went away when i swapped wheels around, but i have changed them around again a while ago and its doing it again. would it be a wheel alignment issue? some of the wheels have some small weights on them, but do they need to be equal weight on each side of each axle? i dont know what theyre used for exactly
  2. minux
    minux Infidel Bear
    Are they directional tyres? If so check they havent put them on backwards, thats teh noise they make when they are.
  3. stocky
    stocky New Member
    yeah theyre on the right way
  4. stocky
    stocky New Member
    bump. still got the same problem and not sure where to start
  5. minux
    minux Infidel Bear
    The weights may not be equal due to each wheel balancing slightly differently.
    Drop by a beaurepaires and see what they say? It could just be the wear on the tyres perhaps?
  6. stocky
    stocky New Member
    hmm tyres are new though. might have to take it to a tyre shop if thats the problem. when i can be bothered ill drop by a servo and check all the tyre pressures too
  7. VL-187
    VL-187 ZZZZZZZZTUUUTUUUTUUU
    Bagged VS calais II
    might of lost a weight off one of ur wheels?? or slight buckle in one of them??
    i had big trouble gettin my wire wheels spot on with balancing, so ended up getting a on-car balance and it fixed it straight away..
  8. stocky
    stocky New Member
    hmm i have a whole heap of 5g and 10g wheel weights spare. i should stick some on trial and error and see if that fixes it haha
  9. VL-187
    Bagged VS calais II
    yeh no harm in trying if u can be bothered lol, most likely one of the fronts..
    goodluck with it..
