JCL
- May 30, 2013
- 42
- 9
- 8
- Location
- Monbulk, VIC
- VS V6 Ute
So I have been doing a few fixes on my VS ute ecotec due to a really rough idle/misfire when cold and under power. One thing i have been putting off for a while is to replace the inlet manifold gaskets (ive got some oil in my coolant). They probably arent the cause of my issues but while the ute is sitting in the garage i decided to do them and bought some Mace ones for some longevity.
After replacing them and putting everything back together i noticed i didnt have anything to connect into the bottom (underneath) of the throttle body and just had a small hose elbow connected there dangling and connected to nothing. After some digging on here i think i worked out that the purge control solenoid on the back of the motor on the drivers side should be connected to it by a hose. I checked the solenoid and it had one hose to connect to the carbon chamber and another small hose (5 cm long on the bottom outlet) connected to nothing.
So a couple of questions if anyone knows:
If anyone has a picture of where the bottom outlet (right underneath) of the throttle body goes that would also be awesome
Thanks
- Am I right in assuming the bottom connection of the purge control solenoid should be connected to the bottom/underneath outlet of the throttle body?
- What sort of issues would this cause? I have no idea how long it has been disconnected for but i would assume it may never have been connected in my time owning the car (3 years) For the majority of my time with the car i have never had any issues
- What sort of hose connects the 2 together? Is it that really thin plastic hose that is connected to the carbon chamber?
Thanks
