putting a vn motor in a vp lexcen
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by nomrcymick, Jan 27, 2012.
  1. nomrcymick
    nomrcymick New Member
    gympie
    vp lexcen
    hey was wondering if i have a motor out of a vn with wireing harness n computer will it fit staight in my vp lexcen
  2. Jxfwsf
    Jxfwsf Well-Known Member
    Aus
    commodore
    yes it will, don't even need to change wiring and ecu, just the engine
  3. hi_ryder
    hi_ryder Donating Member
    Pascoe Vale South, MEL
    i changed a vp lexcen to early vn calais. but i changed the entire wiring loom including the dash loom, body loom, engine and computer. if your not going to change the dash and body loom theres just 2 plugs in the engine bay that dont match up off the engine loom and will need to be modified.... its just the plug heads themselves, theres no extra wires or anything....
  4. Jxfwsf
    Aus
    commodore
    what year vn engine and loom do you have? if it's a later vn the plugs will match
    early as hi_ryder says needs to be changed aswell as the dash to engine loom
    late vn will match vp no changes needed
  5. nomrcymick
    gympie
    vp lexcen
    thanx guys its a series 2
  6. Jxfwsf
    Aus
    commodore
    it'll go straight in then with the loom attached or you can just swap the motor and use your existing loom without having to remove it from the car
