putting a vs front on a vn
kyleat1
vs ute
im thinking of putting a vs front on a vn i wont to know how hard it might be and wont to put a vs dash in it as will
SweetWagon
booosted
Springwood NSW
VS Berlina Wagon Supercharged
I'm also planning to do this. Its easy, just bolt on stuff. You need VR/S guards, bonnet, front bar and headlights from a wrecker and fit it all, and get it sprayed to match.
I dont know about the dash though
Torquen
Boost FTW
Perth, WA
450+ HP FORD XR6T
new thigns possible but at what hassel and cost is another thing. bumper should be easy enuf...dash may be a problem. your looking at all new wiring for a start.
N
nemodore
Guest
the panels arnt just bolt on, the rad support panel has to be cut back on the edge inside the guards to allow for the vs guards and the head lights need the inner bracket cut off and a new one welded in . the dash is simple but requires a bit of knowledge to get right. if you guys need any help give me a pm and i will help you out as i have just done these mods to my vn.
Rhino Racing
vn/vp Speedway Street Sedan
VN with VR Panels Pic
Here is a pic of mine that i did recently.:D
It is a vp with v r/s fibreglass guards.
Not for the street. it is just a race car only :dance:
The front guards bolted straight on but i cant vouch for the bumper etc as i have modified bar work under the bonnet that is all part of the roll cage and the bumper mounts to this.:thumbsup:
holden007
VRII
Subaru Liberty
I reckon just get a VS. Same you the trouble and will not set you back far.
evil_monkey
Australia
Holden
either that or go the whole hog and get a vr/vs statesman front end put on a vn i doubt the cost would be a hell of a lot extra than a conversion to a stocky front end
holden007
VRII
Subaru Liberty
or buy a VR, same engine as the VN with the VS look.
cruzn
vr Commodore
VR does not have the same engine as the VN, they just look the same. VR has different pistons and crankshaft bearings whitch increase the commpression. Also differnt ignition. E.g. different harmonic balancer crank spacing. Thus better fuel economy
