Photo Time
Got the new Turbo 700 trans speedo drive bracket today ($25) so now I can put that back together.
Figured out the original nissan/holden box had a 17 spline driven gear though I am still on the hunt to find out how many teeth are on the drive gear (so i can figure out the ratio). Have been told that it is part of the output shaft on the autobox and not a seperate drive gear like the t700 is.
Dash cluster.
I decided that because I will no longer be using the power button from the original trans that I would remove the image in the warning panel and insert the engine check lamp in its place. This was quite easily done (about 30-40mins) and simply involved cutting the engine check from the VN dash I had at home and connecting the ecu engine check lamp wire to the old trans button.
While I was at it I used the spare lamp on the left hand side of the warning panel and with a bit of rewiring added the engine oil check lamp to it. (you can just see the green trace wire leading to it as a little soldering was required for that one
Big Brake upgrade
As previously mentioned I decided not to spend $1000 - $1200 on the VT (or more for the VE brake upgrade) kit. One day (money allowing) I will buy the VE kit but for now funds are getting tight.
So I come up with a new solution for you all that only cost me $450 which included new VL 290x22mm Rotors, Mazda RX7 FD3S Series 6 4 pot calipers, New Mazda pads.
The Mazda caliper would bolt directly up if the Holdens spacing was wide enough but its not, the Holden is 78mm while the Mazda is 160mm
Here is the difference in the VL Commodore caliper (left) and the Mazda RX7 Caliper (right). As you can see the bolt spacing is miles out.
To remedy this you need to make up two plates from some 200mm x 30mm x 6mm (or 40mm wide if thats all you have like I did). Next drill the 4 holes as shown remembering to offset the inner holes down 4mm from the outer holes (6mm would be fine as well as this only aids to push the brake pad closer to the edge of the caliper).
Next use the original bolts that held the caliper to the strut and reverse mount them as such using nuts to tighten.
The tricky part is next as you need to somehow insert the spacers under the plate to take up the space between the caliper and strut. Once done tighten up with some new bolts into the factory strut mount position.
If you dont mind the word Mazda on the caliper then your big brake 4 pot upgrade is complete for about $400-$450.
Note: I have been told you can mill the Mazda lettering off as long as you leave the ridge there as the ridge is the fluid channel between the outer two pistons. I have not tried this but googling does show it to be a common practice
So there you go.
A 4 pot caliper 290mm rotor setup for $450.
I havent tested the stopping ability yet but the factory Holden master cylinder is 15/16 and the Mazda one is 13/16 so it should actually make a harder pedal as well. guess time will tell
Q
