Troy711 said:
just a quick question to those who have lowered a VZ ute with superlows. did you need to change anything else apart from the springs? shocks, camber kit... anything? and how much did it all set you back?
cheers
I lowered mine with lovells super lows
cost around 180 pair for springs
used original shocks ( mine being ss has fe2 already so kept original shocks)
Fitted myself - took about 3 hours all up ( rear is piss easy but front a bit fiddly as you have to compress springs - used air tools so made job easier)
No camber kit - when had it aligned after fitment ( day after picking car up) tyre place told me settings were good - however i have found that i do get tyre wearbut it handles really good. i talked to them again after fitting second set of tyres and they told me with the settings i have a camber kit would not help much as the main problem is when the back end squats when under acceleration which in my case is a fair bit
If anyone has better personal results from fitting the camber kits love to hear about it but at this stage i will just live with the way it is as the handling is great and drives nice
Hope this and the picks help
