question about LSD's
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by lowrida56, Nov 27, 2006.
  1. lowrida56
    lowrida56 Member
    VN Calais 5ltr
    if a lsd is completely worn out (i do a burnout and it will only ever do singles), when you jack it up and spin one wheel will the other wheel spin the opposite direction or the same direction?
    reason im asking is its out of a manual vn and i was told all manual vn's have lds's but this only ever spun one wheel
  2. JD
    JD Donating Member
    Deep South, SA
    1.6L Turbo Holden Croooooooooooze
    a LSD's wheels will both spin in the same direction
    even if its worn out it still should unless all the gears have been stripped
  3. azkwazere
    azkwazere Ahhh Yes, Ahhh Yes....
    .....SE Burbs
    VP 5-SPD / 24-SPD Racer Hybrid
    When an LSD starts to wear, the slip will increase so it will progressively turn back to a single spinner.. the limited slip bit gets less limited, then things snap and break and damn...
    as for the vn manual thing, who told you that??? As far as i know thats a load of crap...
    aZk.
  4. 1991_Vn2nV
    1991_Vn2nV New Member
    Gumeracha, Adelaide Hills
    91 VN Berlina & 03 VY Berlina
    haha what a load of b/s...
    No not every manual VN has/had LSD.. hardly any do... Unless its a V8 in which it was a more common option.
