eetmesoon
- Apr 8, 2012
- 60
- 12
- 8
- Age
- 42
- Location
- Australia
- VX SEDAN...AND A VE TOO!
Battery issues again; went to start my VX Saturday 20th June...zippo! Zilch! Not even enough battery power to unlock the doors. Battery visigauge was showing "red" so I guess it was cactus. Bought a new 540 CCA battery on Monday. fitted to car Tuesday....checked all connections, tested and car started no issue at all. Left if for a couple of days and went to get some items from inside the boot. Opened and retrieved from boot - easy! Sunday 28th go out to go for a drive...battery dead flat again...WITH NO USAGE!!...so I put my old Arlec automatic 12v charger on and leave it charge for about 11 hours. Go out to check...still flat and not able to operate doors.
Consider it an unlikely possibility that there MAY be a leak somewhere within the Electrical System that caused the batteries to discharge...so I disconnected leads from battery to car...and then connected the Arlec to the Battery. Left if overnight for a good 12 hours....go out to check and battery still as indicated by Red on the visigauge.
So I call the Autobarn shop where battery was purchased...they tell me that as it's a newer Calcium battery...an older charger won't work properly and his story sounded convincing, but am still not sure.
Seeking advice here from Members more knowledgeable than me...my question; Has battery technology and manufacture changed so much that older type battery chargers are not up to the task of completing a re-charge? As far as I was aware the Supercharge SMF58VT Silver Plus Battery was just a normal Lead Acid type Battery...
