question on the VS super CAI onto a v8
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by sebstenator, Feb 25, 2008.
  1. sebstenator
    sebstenator Burn
    VN SS 5.0
    what size is the vn v8 throttle body?
    and the VS supercharged CAI.
    i think it should be ok but i was wondering if i would have to make the hole a bit bigger in the vs airbox or anything like that if it would be restricted or anything like that.
    just wanted to clear it up
    cheers
  2. Boonz
    Boonz Donating Member
    berri, south australia
    green 355 VG ute
    the super 6 one wont fit cos of the shape and position of the fan shroud....
  3. sebstenator
    sebstenator Burn
    VN SS 5.0
    i dont have a fan shroud iv got twin au thermos.
    and i asked about if the hole on top of the airbox was gonna be a restriction not if it fit.
    cheers for the injectors by the way bro.:thumbsup:
  4. Bz Kn33z
    Bz Kn33z Active Member
    Mildura
    Black VN V6 Turbo
    V8 TB is the same size as a v6 one but has a 65mm butterfly insted off the 60mm V6 one it should be fine with the box cause its 3inch outlet so should be fine with the Twin thermo it the top shroud flat to mount the CAI on? just need to line everything up and make sure it doesnt rub on the bonnet good luck.
  5. sebstenator
    sebstenator Burn
    VN SS 5.0
    yeh its flat should be fine. just need some minor modification with a heat gun also open it up a bit and so on.
  6. Bz Kn33z
    Mildura
    Black VN V6 Turbo
    Yeah with my VN with the S/C CAI on the opening on the CAI i cut it back to the line so it allowed more air flow good luck with it.
