Questions about doing head on VS Ecotec
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by ragrim, Jun 14, 2008.
  1. ragrim
    ragrim New Member
    2012 VE SV6
    Ok simple question...
    Gregories manual says to loctite the head bolts, do i have to?
    Gregories manual says to replace rocker retainer bolts because they are a torue to yield type and can only be used once, do i have to?
  2. DannyboyDS
    DannyboyDS Just hand me the pliers.
    VS Berlina
    no and no.
    HOWEVER.
    Although you do not HAVE to do these things I would suggest you use the loctite as it is cheap and effective and it may save you hassels later on, I always use, ive never had anything rattle loose.
    as for the bolts my Haynes manual says the same thing, but i'd say it would be fine, having said that if the bolts are under $20 i'd just buy them to be safe.
  3. ragrim
    ragrim New Member
    2012 VE SV6
    decided to wait and do it right, which is annoying, i was hoping to have my car running by tomorrow, now ill probably have to wait till tuesday to get the right bolts, not happy jan, 3 days without my car and im missing it.
  4. DannyboyDS
    VS Berlina
    but at least when you put it back together it has no excuse for failing on you aye?
  5. ragrim
    ragrim New Member
    2012 VE SV6
    this is true, im the kind of person that wants things done today, and generally take shortcuts to get it done, thing is im no mechanic, and if one of the bolts snap, im realy ****ed. so i think in this case its probably better to wait it out and do it properly... realy sucks though cause i miss my car.
