Questions re. LS1 motor & transmission...
Vt_vic
perth,Western Australia
carless for now
piston slap was due to the mexican factory that made the ls1 there was too much clearance at the top of the piston and made the piston slap the sides of the block instead of a smooth ride
Bravotwozero
MY12 AMG C63 W204 Speedshift + 2013 KW T909
And that's the way Holden wanted them. Reason was apparently due to getting better fuel economy. Way to go Holden
Sabbath'
Redblock Jesus
80 Series// VFII Black Edition
That's bullshit. Do your research.
The slap is caused by side clearance, not top clearance. The "Slapping" is caused by the cylinder to bore clearance being excessive. When the engine warms up, the expansion of metals takes out the clearance and the slap will go away.
It's a design flaw/fault with the motor, specifically the piston skirt design/length. The problem plagued LS1 motors right up to VY.
7100brendan
62
Shepparton, Victoria
2004 CV8 Monaro
Fantastic !! thanks for the tip - it was a pretty safe bet that someone else had already done this conversion .....(but I had no idea there was an entire forum dedicated to these LS1 motors.....) - that story should help heaps.....
and thanks djm8 - The donor motor/box combo's I am looking at are basically all complete running units, including ECU and full harness. This *in theory* should make the actual conversion itself fairly straightrforward........I have done some engine transplants in the past with 308's, and also slotted a 250 2V motor into an XB panelvan many years ago, I am hoping that if engine and gearbox mounts are available from somewhere like Castlemaine Rod Shop, then I will do most of ther hard yards myself.........
:thumbsup:
Hi, this is very old thread however I am investigating fitting a LS1 & four speed auto into a 1971 Jaguar Series 1. I saw a few posts from yourself and others on the topic and I was interested to see if you actually went ahead with the project? Cheers, Brendan
Gosling1
62
VN Commodore Series 1
Hi Brendan - yes its an old thread and yes I am still working on this conversion. Been a lot of progress since the last updates - the exhaust system is now fabricated and fitted, the engine & trans are in the vehicle and a tailshaft has also been fabricated.
I am currently working on the electrics - a complete VY ECU & harness has been obtained for the conversion and I am sorting that stuff out now.
VS 5.0
Pics please.
  • Like
Reactions: Lex
Gosling1
62
Gosling1
62
