quick help
MAC-VN
vn90
ok guys i need to get a wire form my motorbay to the inside of my car whats the best way to do it
vns1
SweetWagon
booosted
Springwood NSW
VS Berlina Wagon Supercharged
MAC-VN
vn90
AHAHA THANKS wish i had of known that early i just put push the otherrubber mouth thing were the driving lights n things go n put it throw there ah
ill probly go back one day soon i really tidy it all up n stuff kinda half assed it for now got a tatto healing n its hard to work on car without hitting it ahah
VR38
VB SL/E
Just make sure it does not cut thru the insulation where the wire passes thru the body as you may have a car fire if not fused correctly.
Fun_Bucket
35
Cairns White Rock
Cruze II sri
ever since i removed this gromet to run leads through, i can hear my coolant being cycled through, from inside the cabin..Normal??
WhyallaVp
Vp Berlina
Whyalla, SA
VS Clubsport
Sure its not air in your heater lines? It should sound like a squishy sucking noise if it is. Wait for a cold start, open your radiator cap, turn on the heater and watch the level drop. Then top it up and it should go away.
calais_cruzin
Calais_Rattling....
Gold Coast
92 VP Calais 3.8
motorbay lmao.
yeah holedncommodorevp , jst do what WhyallaVp said, u heater core probs running a bit low, had mine do this last coolant change, didnt have the heater tap open soo it fully drained, but couldnt top up itself.
It does give a nice slushy noise aye
Fun_Bucket
35
Cairns White Rock
Cruze II sri
yeah it's sounds like a slushy noise...it never used to happen until i ripped out that gromet...So what are you saying, take the cap off the radiator, and just turn the heater on../?
calais_cruzin
Calais_Rattling....
Gold Coast
92 VP Calais 3.8
yeah turn the heat up, it will open the valve to the heater box, then ur fluid level in the rad will drop as the core fills up.
Mite not drop that much only needs a lil bit of air in the system to make it slush.
Mite have hit sumfink when ur were under there, mite have a slight air leak on the heater hose join at the core, doubt it tho.
