quick Question:P
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by jas98, Jan 11, 2009.
  1. jas98
    jas98 Active Member
    maryborough QLD
    vs commodore V6 S2 and a BA XR6T
    does a VS v6 have a EGR valve?? if so where the hell is it?
    cheers
  2. DannyboyDS
    DannyboyDS Just hand me the pliers.
    VS Berlina
    Assuming EGR and PCV are the same thing, yes it does, it is located between the plenum chamber (top half of the inlet manifold) and the inlet manifold (Bottom half)
    Its not a massive job to replace it, but its not the best fun either.
  3. VrWagz1
    VrWagz1 The Wagon on Wheels..
    wollongong
    VE SSV MY09 Auto Wagon
    WTF is EGR. ^^^^if its a fancy name for the vent line then yes
  4. jas98
    jas98 Active Member
    maryborough QLD
    yeh i was under the impression it was the PVC valve but looking on Ebay i saw a listing for this:...HOLDEN VT VX EXHAUST GAS RECIRCULATION EGR VALVE - eBay Engine Parts, Engines, Components, Car Parts, Accessories, Cars, Bikes, Boats. (end time 07-Feb-09 15:18:31 AEDST)
    it says for a V6 ...i know its a VT/VX but isn't the engines the same in the vt as to the VS??
    reason why i ask is i have been trying to find out what the noise is in my car as its a high pitch whistling noise that is there when i accelerate low to mediu but if i accelerate real quick there is nothing. I have checked all vacuum hoses and all seems good only thing i can think of is a gasket leak?
    cheers
  5. SweetWagon
    SweetWagon booosted
    Springwood NSW
    VS Berlina Wagon Supercharged
    EGR (Exhaust Gas Recirculation). I know the VT has it but unsure of the VS, if it does it is located on the passengers side exhaust manifold. It basically recirculated exhaust gases back into the intake manifold for pollution etc..
    You sound like you have a vacuum leak, unlikely to be exhaust related..
  6. jas98
    jas98 Active Member
    maryborough QLD
    thanks for that. yeh looks as though the VS don't have one. Will check over vacuum hoses and inlet gaskets etc tomorrow and see how i go
    cheers
  7. moff_man
    moff_man operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    vt they started for euro 3 emissions also ecu monitors fuel level and miss fire detection
  8. immortality
    Sth Auck, NZ
    No EGR on the VS. for those people that do have it on later models, i suggest the Raptor style EGR Gasket "support" plate as a great mod:whistling
  9. Not_An_Abba_Fan
    Not_An_Abba_Fan Exhaust Guru
    Bunbury, WA
    Strange Rover
    PCV valve is the Positive Crankcase Ventilation valve, all it does is vent crankcase pressure into the intake manifold. The EGR is totally different and as immortality has already said, the VS does not have one.
