Quick Question
Discussion in 'VZ Holden Commodore (2004 - 2006)' started by ashbox, Apr 20, 2012.
  1. ashbox
    ashbox back in black
    The Car
    something black
    ok....
    i got the car back from a service today and was told my input shaft bearing is making some noises... its a vz 6spd ls1
    Now the car yard says its not covered under the extended warranty..
    my question is,
    would that part be considered part of the gearbox components or clutch components??
    Cheers for the help
  2. Reaper
    I don't see why/how it wouldn't be covered by a warranty. You are doing *real* well to trash a input bearing nomatter how bad you abuse or thrash any car. I'd consider it a gearbox component. Clutch = clutch and pressure plate + maybe throw out bearing (very maybe). Read your fine print is my advice.
    Reaper
  3. ashbox
    The Car
    something black
    yeah, i did, and i quote "All mechanical components within the transmission houseing. Excludes bell housing, manual transmission components and torque converters"
    i'm not saying i don't drive the car hard at times, and gioing by what your saying is these bearings are hard to "break"
    its funny, they even recommend going to holden to get it fixed, because they don't have the tools to fix it.
  4. Reaper
    Hammer the **** out of it 24/7 and you won't #### a input bearing. As far as I'm concerned it's part of the box. I'm not sure what your quote actually means. Covered or not covered??
    Reaper
  5. ashbox
    The Car
    something black
    to me it means its covered if its not part of the clutch componentry....
    i'll be ringing holden to find out how much one of these things are and ask if they are a gearbox component....
    might even ring the accc and find out
  6. Calaber
    Lower Hunter Region NSW
    CG Captiva 5 Series 2
    Those extended warranties usually nominate the covered components by stating "all internally lubricated components" or something similar. The input shaft bearing is most definitely "internally lubricated" and is part of the transmission, not the clutch.
  7. ashbox
    The Car
    something black
    yeah, what i quoted before is all they say about the transmission in the warranty...
    definantly will be questioning it tho, cos my guess is, they aren't cheap to replace......
  8. Calaber
    Well, the input shaft is definitely mounted "within the transmission housing", so it's difficult to see how they can argue otherwise. Good luck. Those extended warranties are often worded in such a way they are expensive dunny paper and little else.
  9. ashbox
    The Car
    something black
    yeah, well, it was a free one with the car and then they kindly upgraded me to a 5 year one, to which i prob paid for in the finance
  10. ashbox
    The Car
    something black
    Ok update, their service manager agreed that it was covered under the warranty when he was told its not an external part of the gearbox....
  11. Calaber
    Bloody great service manager if he needed someone else to tell him that!
  12. ashbox
    The Car
    something black
    Ah yup, they're outsourcing the work and I'll be without the car for a week...
    I'll prob ask where it's going and see what condition the clutch is in while it's there
  13. Pickle'
    Pickle' Donating Member
    Sydney, NSW.
    VE Omega
    Mine says excactly that.
    TRANSMISSION
    Internally Lubricated Parts Only. Transmission Case If Damages Are Due To Failure Of Internally Lubricated Components.
