Quicky: VR V6 / VS V6 Clusters identical?
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by VS Omega, Jan 26, 2009.
  1. VS Omega
    VS Omega New Member
    VS Commodore Omega
    Hey all,
    Trying to source a cluster (level 2 or 3), just wanting to know if the VR and VS clusters are the same connection-wise (plug and play) or the looms/lights are slightly different? I notice all of the clusters on eBay are for VR/VS but I thought I read they were different?
    Thanks :D
  2. dufus
    dufus Donating Member
    rickshaw
    Yep VR/VS clusters are the same, as are VN/VP clusters but the two are not interchangeable with each other. So you can use a VR cluster in a VS and vice versa.
    VS Omega likes this.
  3. Fekason
    Fekason Fekason
    Penrith NSW
    Check the green printed circuit sheet!
    As aleardy advised, VR and VS are interchangable. VN/VP will plug in, but have a different circuit, so smoke will appear if the wrong one is used.
    If buying a VR/VS cluster, make sure that the green printed circuit sheet is in OK condition. It is not uncommon for stored clusted to wear away a circuit or two, so be cautious.
  4. VS Omega
    VS Omega New Member
    VS Commodore Omega
    Thanks for the advice guys, helps out a lot... and I know about those damned printed ribbon cables, that's why I need a new cluster. Rep+ for you both
