R/H elec window problems
arj127
NZ
08 VE SS
Some time ago after putting the right rear window fully down and driving around for a few hours with the radio on i came to a stop (with radio off) and heard a strange clicking sound. I soon discovered the window switch had stuck down and was still operating the window. From then on my window will go down 1/3rd maybe and need some assistance to get it started to go the rest of the way down, and the same on the way back up.
Anyone had a similar experience?
I'm sure i disconnected the motor from the regulator a few years ago and the window ran smoothly in the tracks. Am i looking at a motor problem
Am hoping to find some time and see if i can swap the motor from the left door in if its the same and test it.
Dayvo
Because i can
South East,Victoria
VE SV6 Series 2
Pull the door trim off and operate the window and have a look at the mechanism ,you might have stripped the gear or a tooth .Also i dont think the left and right hand motors are interchangable but i could be wrong .
arj127
NZ
08 VE SS
true, a stripped gear sounds very possible
oska
vx custom 600RR
i have a similar problem with the rear
i get 2 clicks on the way down and it slows in the same spots going up i've tried lube on everything nothing helps
should i just replace it
arj127
NZ
08 VE SS
Bought a second hand door today and whipped the motor unit etc out and stuck in my problem door.
All wen't fine and i now have a window operating in perfect order again. Yay
