[Alloytec] Ra rodeo Alloytec
Deo Deo
47
Hobart Tas,
07 Rodeo
G'day all, I need a new engine for my 07 Ra Rodeo. What commodore engines are compatible with the Ra ecu, and wiring?
I have the old motor for swapping over components needed.
Thanks
kev21
46
New Zealand
Holden rodeo 3.6
Have you done the job yet? I did it about 18months back. Managed to fool the stock ECU and Ute is running really well. I'm thinking of redoing the job with a few changes. Currently vvt is disconnected, only uses one cam sensor on the rodeo. But if I run the ve electronics, it would mean a jump from the 150kw to 190kw. My problem is how to integrate all the electronics from two different vehicles. Aftermarket ecu would be the easiest but from what I'm finding available,I just can't afford to spend 3k on that!
keith reed
76
Raceview Qld
1983 vh v8 sle 2000 vs v8 ute 2012 ve11 redline
If you run your cursor over his name you will see he was only on the forum for a week. Possibly because he did not get a reply he went elsewhere.
LesN
69
VE 2 Wagon
Hi there... What VE engine did you use for the conversion?
Vek21
46
New Zealand
Rodeo alloytec 3.6
Ly7, but Leo would have been fine too, because I had the vvt disconnected, ran about 10000km before I decided to try hook up the vvt.
I now have the vvt working, flashed the original rodeo 3.6 ECU with the vz software. Two biggest headaches have been Speedo and fuel gauge.
