hi guys ; i have a v6 series 2 vs auto and yesterday the radiator just started leakin water bigtime from somewhere down in the drivers side bottom of the radiator anyway it leaks real bad empyts in like a couple of minutes itried 2 btls of chemiweld as i have used this in the past on other cars with great success but it didnt even help any1 no if its straightforward to remove the radiator i got 3 metal lines going 2 it and the 2 main rubber water hoses do u just undo the trans cooler lines and stuff ? thanks muzza
Sounds like the side tank has split which means the end of that radiator. Removal is straightforward and as you've described. Try and put a plastic bag over the end of the trans lines with an elastic band to keep dirt out. Good Luck.
If possible try and get the new radiator with metal tank as they use them in Taxis, they last a long time.
