Nemesis_Dawn
- Sep 4, 2016
- 19
- 0
- 1
- Location
- Saudi Arabia
- '02 VX SS A4
So as I said in the title, both my radiator fans on my Commodore VXII SS are always on and on high speed when I turn on the AC. They only shut off a few seconds after I turn the AC off.
I cannot use the AC like this, because the fans will definitely burn out, and the fans loom connector gets EXTREMELY HOT when the fans are on high speed, to the point where anything near the connector gets hot to the touch as well. (I'm not sure if it is normal for the connector to get this hot with the fans on high speed either).
Both my AC compressor and engine loom are new, so there are no problems there, as this particular problem occured even before changing my compressor and engine loom.
What could be causing this? Bad compressor pressure switch? A faulty wire somewhere in the dashboard? Something else?
