radiator leak
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by vxcommie, May 4, 2011.
  1. vxcommie
    vxcommie New Member
    perth
    vx executive
    Today my radiator died, the drivers side plastic bit that connects to the return hose had split, and spilled coolant everywhere. the car has only done 148000 km and this happens, which they are meant to last for more than 200000 kms before replacement?
    Anyway i was wanting to know if i should get an ls1 radiator as these are all aluminum and none of this plastic crap that will break? or if it will fit the v6
    thanks
  2. Cameron P
    Cameron P New Member
    Quakers Hill, NSW
    REDHOT VX SS
    mine died the exact same way at 185... so there is no set time that it should break lol
    do you plan on doing nother 200,000km in your car? if not just buy a replacement radiator lol cost me $170 and fitted it myself.. easy to do
  3. vxcommie
    vxcommie New Member
    perth
    vx executive
    yeh it died around the corner from the mechanics i go to so they are giving me a quote. im sure i can replace it myself just cant drive it without coolant.
    I am abit pissed off with holden that they use this plastic around the radiator, doesn't shout quality. Not sure why they could not have used aluminum like the vx ss ones.
  4. Commo_Carl
    Commo_Carl Member
    Sydney,
    95 VR V6 Turbo Ute, 99 STI EJ207 GT FORESTER
    That's not too bad mileage for it. I got one from ebay, had it delivered the next day for $100. Easy as piss to install. Runs nice and cool and had no probs, even running car hard doesn't affect it. Pretty good quality for a cheap radiator.
  5. Cameron P
    Quakers Hill, NSW
    REDHOT VX SS
    i did mine on the side of the road hahahaha
  6. vxcommie
    vxcommie New Member
    perth
    vx executive
    haha and flushed it ? or filled it
  7. johnno010684
    johnno010684 New Member
    Auburn
    VX Clubsport M6, Subaru Brumby-daily, TM Magna
    ls1 radiators still have plastic tanks the same as v6, they will not fit a v6, get one from ebay for about $100 make sure you run the right coolant concentrate and then top it up with a bottle of distilled water. in my experience i wouldnt try and flush the system as other parts such as water pump may start leaking from removing build up. if you only got 148k i would think someone had been runnning plain water in it somewhere along the line.
  8. DLFHUB666
    DLFHUB666 GIT 'EERRR DONE!!!
    Nhulunbuy NT
    VX SS, PX Ford Ranger XLS Dual cab
  9. wrx884
    wrx884 WA's ASR Rep
    VT Exec/ VT L67 Spac, 5L VP Calais, 77 TC Gemini
    makes u wonder y they changed from bass radiators in the 1st place. least they can b fixed so they r brand new and cost less 2 fix than buying a new alloy 1
  10. graham7773
    graham7773 Active Member
    VT Acclaim Wagon
    They changed from brass, copper and lead solder 1st because alloy ones are far cheaper to make and 2nd alloy ones are half the weight of brass and copper. There is also an environment pollution element in the lead used to seal the brass and copper ones
  11. monkeys437
    monkeys437 New Member
    Mornington, Melb
    VS Stato l67
    Get over it mate you got 10 years out of it and they take 100 bucks and half an hour to replace.
    YEA.355 likes this.
  12. Cameron P
    Quakers Hill, NSW
    REDHOT VX SS
    ohhhhh snap!!!
  13. vxcommie
    vxcommie New Member
    perth
    vx executive
    i agree its 10 years old, but i do have a point, and it has been looked after and changed coolant when it is due
