Radiator overflow tank
maccasparks
Tauranga NZ
VY V6 Wagon
Just doing a coolant flush - went to fill overflow tank to top of neck and it leaks out and holds about half looking down with a light. Is there a hole to prevent overfilling or do I have a leak? Also is there an easy way to remove it - looks like bumper may have to come off.
Sabbath'
Redblock Jesus
80 Series// VFII Black Edition
The overflow isnt meant to be full right to the top. There is an indicator on the yellow stick. And yes, it has a hole to prevent overfilling.
VYMAD
SILVERFOX
BUNDABERG Q
VY EXECUTIVE S2
You don't have to remove the bumper, just a couple of screws or bolts. There is an over flow hole and like said above only fill it to within the 2 triangles on the dipstick.
maccasparks
Tauranga NZ
VY V6 Wagon
yeah cheers for the help- I was only filling it right up while I was bleeding the air out of the block.Didn't want it to run out.
