Radio Channel Changes when wheel moves
Discussion in 'Car Audio' started by LozzaNewport, Apr 25, 2018.
  1. LozzaNewport
    LozzaNewport New Member
    2011 VE Calais
    Hey Fellas,
    So im driving my 2011 ve series 2 calais and i turn the wheel left or right and the channel frequency moves one way or another. And when im playing music on my phone it also changes songs
    Any ideas to help at all?
    Thanks
  2. greenacc
    greenacc Searching for the billion
    VE Berlina
    I'd guess you have a problem with your clock spring.
    RiffRaffMama likes this.
  3. Gridlocked
    Gridlocked Member
    VY II Berlina V6
    Agree with greenac, not familiar with this model however it probably still uses a "clockspring" assembly as a means of electrically connecting the wheel mounted audio controls to the fixed wiring harness in the column. Maybe the "common" connection going through the clockspring assembly is making/breaking contact causing such erratic behaviour of the audio controls. My VYII had same issue a few years back.
  4. John Revill
    John Revill Active Member
    Jordan Springs NSW
    WN Caprice V 6.0L A6
    I have seen this once before and it was the buttons on the steering wheel that were faulty. The springs in the buttons where a bit weak and turning the wheel or going over big bumps would cause the radio stations to change.
