Radio Pin Code for 2017 VF Evoke standard Radio-
GMH Wagon
55
2017 Commodore Evoke Sportwagon 3.0
I have a 2017 VF Evoke wagon with the standard MyLink Audio.
After purchasing it, I noticed there was no security ID card with Vin info and radio Pin.
I’ve contacted Holden both a dealership and Holden assist line to assist with sourcing the pin info, without success.
A. Do these units have a 4 digit pin?
B. How would I source the pin?
I’ve been advised by a dealer that they can source it for a cost, either on the database or removal of head unit to obtain the pin from the rear of the unit.
Can anyone please advise further?
lout
60
Langwarrin Victoria
vf would be canbus linked
so vin number is programmed into unit
after flat battery bcm will poll the other modules and if they all report the correct vin
all is good
so no 4 digit pin
Lex
Geelong Victoria
VT Executive S1 V6 6 speed Auto Wagon
all is good
so no 4 digit pin
Different story if you've bought another oem h/u & installed without updating the vin to the new h/u.
GMH Wagon
55
all is good
so no 4 digit pin
Thank You! Much appreciated for the info. I have nothing to worry about.
  • Like
Reactions: Lex
GMH Wagon
55
Nothing has been changed, still original unit. Thank you for the info.
  • Like
Reactions: Lex
BlackVXGTS
Melbourne, SE
VF uses GMLAN not Canbus, hence you need to use GDS2 to diagnose VF, not Tech2 like the VE. Your other quotes are right on the money.
