J
JohnW
Guest
After chasing this problem for the past couple years, believe I have finally nailed the problem. Given the invaluable information I've gleaned from the forum on various other issues, though I document the 'fix' for the record as it may assist someone else.
Problem would generally follow the following sequence. Airbag light comes on together with warning buzzer, then traction control light, sometimes engine error light, occasionally oil pressure light (and air conditioner stops working when this occurs). Problem would just occur then disappear, returning constantly at a seemingly random basis. Sometime could be near constant (buzzer going off all the time would drive me crazy)
ABS module showed 'date fault'. SRS module showed no error codes. Engine error codes were generally a low speed relay fan fault, a security code fault, and the data fault (what a unhelpful code, means there is a problem in the circuit somewhere). And as everything works off a single bus, it can be in any module, connection, or wire.
All the usual suggestion to fix this type of problem were tried .....
ABS module replaced, twice
Low speed fan relay replaced
Thermo fans replaced
SRS module replaced
Connections to BCM and ECU/PCM checked and cleaned
All to no avail. FINALLY (should have been the very first thing I did) was replace the Airbag and ABS fuses. Problem seems to be fixed. It's now gone the longest without the problem returning so I'm pretty confident this was it.
I didn't check the fuses previously on the assumption they are either working, or blown. The apparent problem is corrosion on the fuse 'blades' creating a poor/intermittent electrical connection in their holder. On the assumption this is the problem, I replaced every fuse in the drivers compartment panel with new ones to avoid possible problems with other circuits in the future.
Hope this may be helpful to someone else. In researching this problem I noticed quite a few people with a similar type of persistent problem despite the usual 'fixes'. I'll update this thread if the problem does reoccur.
SRS module replaced
