PappaYeet
- Apr 19, 2020
- 48
- 10
- 8
- Location
- Adelaide Hills
- VT Berlina L67
Hi everyone. I've tried searching but no one else seems to have quite the same issue as me. Car is a 1999 VT Berlina, series 2, auto, L67. 290000km on it.
Current mods are 10psi pulley, 1.95:1 roller rockers, W2A intercooler, Mace CAI, Mace memcal, ported supercharger and 82° thermostat.
--- The problem ---
When the car is at idle (in gear or park), it will occasionally stutter, as if it misfired just once. The revs will noticeably drop by a small amount. This is completely random, and will sometimes happen a few times in quick succession, or not do it at all. This is present even when moving, provided no throttle is being used (idling down driveway for example).
At times the idle just seems 'rough' and almost always has a rich fuel smell from the exhaust (although could be due to no cats).
When the car is cold, changing from gear to netral or park will cause a large stutter, and the engine will shake as if it is running on 4 or 5 cylinders. The revs drop considerably. The severity of this is random, and seems to be much less frequent when car is at operating temperature.
When driving normally (using throttle), the car runs perfectly. I've never had any misfire when accelerating, whether the supercharger is making boost or not.
--- What I've tried ---
Video of stutter while changing gear
TunerPro log of random stutter while idling (definition file included)
--- Ideas ---
I know it's not really a big issue or anything as the car still drives fine, but it's definitely annoying and I'd love to figure it out. Thanks for any help or suggestions.
--- The problem ---
- Clean IAC, throttle body, MAF, supercharger, intake manifold, intake ports, air filter.
- Checked all vacuum lines for leaks. Could still be a leak hidden somewhere but definitely not the tube from bottom of throttle body.
- O2 sensors function as expected, although issue mainly happens when cold so shouldn't matter.
- Replaced injectors with new.
- Tested fuel pressure and regulator, all within spec.
- Replaced fuel filter, engine oil and trans fluid recently.
- Replaced intake manifold gaskets.
- Replaced supercharger and throttle body gaskets.
- Replaced rocker cover gaskets.
- All intake related bolts are torqued correctly.
- Replaced spark plugs (NGK BPR6EFS-11), leads, coil packs (Mace high voltage) and DFI.
- Replaced valve stem seals, lifters and valve springs.
- Replaced battery and belts.
--- Ideas ---
- The IAC valve steps value changes when the stutter occurs. Don't know if this is cause or effect.
- O2 sensors are old enough to replace. Will do this soon as I will be fitting extractors/new exhaust.
- Something trans related? I know it slips a bit from 3rd to 4th sometimes.
- Haven't done a compression test yet, will do one soon.
- Something tune related?
