vaertigo
- Sep 9, 2005
- 55
- 0
- 0
- VYIISS6m
Chirping from Ls1 rear/underneath - Issue located
Update: Found what the problem was, seems that one of the struts holding the exhaust in place between the headers and Cats had snapped in half, and is causing a resonance.
Hey all, just seeing if anyone has had a similar episode with their LS1. I noticed what could best be described as a metallic chirping sound coming from the car the other day driving home from work, and it only seemed to occur whenever I took off from a standing start, usually at the slip point between the clutch and accelerator. Got the car home, and sat it with the engine going with someone revving the engine with the clutch out and car in neutral, and the noise reoccured with revs. I sprayed a bit of WD 40 on some of the belts cos I thought it might be a noise coming from something squeaking/loose, but I'm still getting the sound, which with the bonnet open sounds as though it is coming from the rear of the engine.
