So when i shake the exhaust form underneath there is a rattle coming from the centre muffler like the pipes in it are loose and when driving it is a loud rattle when going over certain bumps. Whats the best fix or should i just replace the mid section?
Alright what is a good exhaust to replace it with, I will keep everything else stock besides the mid section and i dont want to pay too much either
I dont think changing the centre with anything other than oem is going to give you any gains: An exhaust shop may be even cheaper that replacing the whole center section, depends on your skillset. Have a look on ebay or gumtree in your area ie: VE SS UTE Exhaust in Mentone, VIC | eBay ve ute exhaust | eBay ve ute exhaust | Parts & Accessories | Gumtree Australia Free Local Classifieds
Alright cheers so nothing will change my sound without changing rear mufflers aswell? Will have to talk to a local exhaust shop i guess
As per previous threads (and PM's), as you engine is the high output/195kw SV6 engine, you'll be fine with any SV6 or SS exhaust, as long as you keep your stock mufflers, or SV6 mufflers (as we worked out, SS mufflers do not fit in omega rear bar with twin exhausts) You'll probably find your local exhaust shop has a pile of SS cat back exhaust systems sitting in the corner ready for the metal recyclers - I know the exhaust shop near my work did (but they sold any HSV or SS mufflers they had at a premium ) As wwilde suggested, gumtree is probably your best bet (depending on your location) or maybe eBay
Yeah i only plan on replacing the mid section so will see what the local shop has there or see if they can simply just repair the muffler
