rattle in rockers.
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by coolvxss, Sep 3, 2007.
  1. coolvxss
    coolvxss New Member
    canberra
    5sp VN Executive1988, VX SS 6sp
    There seems to be a rattle coming from under the rocker covers. well at least i think its coming from there. When i have it in neutral and rev it to about 2000rpm and keep it there. you can hear a pretty loud rattle. And when im driving my car, i can here the rattle, mainly when its under load, like when im going up a hill and wrong gear. or if i put my foot down the 4th gear and its labouring a bit. it sorta sounds like pinging but i have tried all fuels and everything but it still does it.
  2. mischa
    mischa Donating Member
    Ruse, NSW
    355 VN GRP A REP
    if i think ur disscribing what i think you are, i got the same proplem
  3. azkwazere
    azkwazere Ahhh Yes, Ahhh Yes....
    .....SE Burbs
    VP 5-SPD / 24-SPD Racer Hybrid
    pull the rocket covers off and see if anything is loose!
    aZk.
  4. coolvxss
    coolvxss New Member
    canberra
    If i take to cover off. is there a gasket or anything there that i will have to replace if i take it off?
  5. mischa
    Ruse, NSW
    355 VN GRP A REP
    apart from hearing it while driving, mainly when the engine is working hard, i havent looked into it any further.
  6. azkwazere
    .....SE Burbs
    yup, its called a rocket cover gasket, cant member any part numbers or anything.
    aZk.
  7. Not_An_Abba_Fan
    Not_An_Abba_Fan Exhaust Guru
    Bunbury, WA
    Strange Rover
    Another Commodore with a rocket? They are called rocker covers because they cover the.....rockers....sorry, had to be said.
    Harmonic balancer can make that same noise and it can sound like it's coming from the rocker covers. How long has it been since you have done an oil change? Use a 20w50 oil if you don't already, and if it is a tappet noise, you will find it will diminish.
    Morton likes this.
  8. coolvxss
    coolvxss New Member
    canberra
    i use 10w-40 oil at the moment. have since ive had the car. I just changed the oil few weeks ago. next oil change i might try 20w50
  9. Emackulation
    Emackulation Banned
    SE Queensland
    '92 HSV VP GTS
    10-40 is too thin, am laff at ROCKETS.
  10. tyrefryer
    tyrefryer New Member
    Commodores!
    you know you can check ur rockers by taking the cover off...those gaskets are just a rubber seal that fits into a channel in the cover so u dont really need to replace it..
  11. tyrefryer
    Commodores!
    and lol at rocket covers...my old man calls them that...and he also thinks the tyres have good thread on them...well at least he knows what he's doing when it comes to motors, names arent all that important
