Rattle Sound Over Bumps in 2015 VF
Discussion in 'VF Holden Commodore (2013 - 2017)' started by Robbo1999, Dec 10, 2019.
  1. Robbo1999
    Robbo1999 New Member
    Eltham
    VF SV6 MY14 Sports Sedan
    Anyone have this problem when hitting bumps even small ones. Loudish Rattle sound coming from the front left side of the car?
  2. Sir Les
    Sir Les Active Member
    VF Calais V V6 MY14
    Been there, done that. One possible source of rattles and knocks is the door striker. The VF has a different design to previous models, with a nylon part omitted (to save money, no doubt). Try wrapping some electrical tape around the striker pin on the door frame.
    Alternatively, check that the window is fully wound up. The slightest opening can cause a rattle over bumps.
  3. Anthony121
    Anthony121 Well-Known Member
    VF SSV Redline MY17 & VF Director
    Is it suspension?
  4. [paradox]
    [paradox] Active Member
    VF2 SSV-R
    rattle id say swaybar links or knocking i would say strut top mount
  5. Robbo1999
    Eltham
  6. Robbo1999
    Eltham
    cheers but don't think that's the problem as the rattle sound is coming more from the front left of the engine rather than around the window.
  7. Robbo1999
    Eltham
  8. Robbo1999
    Eltham
    Yeah cheers i think it is the swaybar link just needs replacing. The car is due for a service is getting your swag bag links replaced expensive?
  9. BlackVXGTS
    BlackVXGTS Well-Known Member
    Melbourne, SE
    Shouldn't be too expensive. Looking at the VF Workshop manual, it seems to be a fairly straightforward and fast operation (unless I've missed something). Other members may give you better information from their personal experience.
  10. [paradox]
    VF2 SSV-R
    last time i had links replace was on my VT from memory, i dont think they were expensive.. but that was a while ago now
  11. 426Cuda
    426Cuda SUBLIME!
    Wagga Wagga
    VF Redline Sedan - A6 Spitfire MSE...
    I'd say it's the away bar struts too. Depending on the type of sound you're hearing though, it may be worth checking that the aluminum exhaustl heat shields are tight.
