Rattle/Ticking from engine passenger bank | 2010 VE Commodore LF1
Discussion in 'VE Holden Commodore (2006 - 2013)' started by RedRoo, Jan 21, 2019.
  1. RedRoo
    RedRoo New Member
    Gold Coast
    2010 Commodore VE International 3.0
    Hi all,
    I acquired a 2010 VE Commodore International. There is a rattle sound coming from the passenger side engine bank. It is noticeable only at low revs. When the engine idles at +-1100rpm, there is no rattle. When it drops to +-550rpm it starts to rattle.
    The engine has 150kms on it. It had timing chain/tensioner/guides replaced at 140kms. The rattle is affected by revs, speeds up with revs.
    It has been rattling for 7000kms plus, that I know of. Since it has had three oil changes, two flushes, oil filters replaced. (5-30)
    Cam actuator has been replaced, made no difference. Purge solenoid replaced.
    Oil pressure was tested to be at low end of acceptable range.
    The car does NOT suffer any driving issues. No check engine light. There is no noticeable power loss.
    Video uploaded:
    @15”
    Could anyone help me diagnose this sound please? Any ideas?
    Thanks.
  2. commy vk
    commy vk Active Member
    South Coast Region
    commodore ve
    Get your torch and have a look at the rear pass side top of motor
    should be a black box with a vac line attached(don't know what it's called)
    With the car running touch this box and if it's stuffed you'll have to replace it.
    Pretty easy job.
  3. RedRoo
    RedRoo New Member
    Gold Coast
    Thanks. What is the function of this box you describe above?
    PS. The video is uploaded now.
  4. commy vk
    South Coast Region
    commodore ve
    It's called the Evaporation purge valve solenoid
    It recycles fuel vapours from tank to the intake
    Should only blow one way when you disconnect
    There is reference on this forum.
    Good Luck.
  5. RedRoo
    RedRoo New Member
    Gold Coast
    Thanks but this is what I meant by ‘purge solenoid replaced’. Wish that solved it. :) Easy fix indeed.
