RB30 Engine Troubleshooting/Maintenance Step by step
VL Berlina 5speed
Apprentice Panel Pusher
35
Project VL Show car, VS Exec, VY Ute, YZ250F
cheers for that:thumbsup: , yah i totaly over looked that thread, didnt rember it was there :bang:
VL Berlina 5speed
35
updated the first post,
was a little fault in the info which was corrected on SC which i was not aware off.
so bumpsy to the top once again
comando man
wellington / nz
rb30 r33
so if i clear the memory it will still work aye like does that just clear all the codes that show
detox_nath83
Another VL Driver
40
Queensland(Sunny Coast)
VL Turbo Commo
yeah it just clears the codes... so if u clear it and then run a diagnostic again u will only have the faults display and not previous ones
lukee1986
gagebrook, tas
vx series 2 2001 3.8 lt
how do you do these tests or where to start if your car isnt within specs 750 give or take at idle as thats what im trying to fix idling at 3 - 500 rpm
lukee1986
gagebrook, tas
what do u mean by turn the ignition on and the voltage reading should be between 1.26V (lean) and 1.32V (rich). this is the base setting and if it is out then the AFM wont be able to be adjusted to a satisfactory mixture (meaning you need a new one)
and just for interests sake you can test the mixture by putting the probes on wire 1 and 3 with the key on and measuring the voltage. 3.6V is the factory setting which is lean, with 2.0V being rich.
so if i turn on ignition its goin to give me a ready of 1.2 1.32 but then you say to turn it on again or do u mean start the car as its confusing how can i turn it on twice and get 2 different readings
and by the way this info is copy and pasted out of gregory's hand book for vl give credit were credits due not taking the fact that it was p[roberly typed and put iin order so still alot of work involved
