rb30 into a VR/VS
h0Ld3n`VN
NO CAR ATM.. -.-
i know vn_luke put a rb30 in hes vn but i was wondering if its legal for a vr/vs??? for me to get a rwc for it in victoria na rb30 too.. but turbo it after rwc
cheerss guys :)
pjdm1980
Shut up Jr I'm thinkin!
Geelong, Victoria
E1 GTS BUILD NO# 007, GQ Patrol.
I think your only aloud to do it in VN's becuase they came out in 1988 with the VL's. if you do it with a VR/VS it won't pass emissions as it is a later car with an earlier engine (HAS TO BE AN EARLIER CAR WITH LATER EMISSIONS IE: NEWER ENGINE NOT OLDER), i think!!!!
greenfoam
102
VP Executive R-spec
It is legal, VR's run the same emissions ADR. A friend of mine is putting an RB30 into a VR ute very soon now. 1997 is when things changed. ADR 37/00 Runs from the start of unleaded in 1986 to 1997, you can interchange any engine in that range of years as they all passed the same test. From 1997 -2003 is ADR 37/01 from 2003-2007 ADR 79/00, then from 2007- ADR 79/01.
You can put anything from the ADR the car came with in or anthing newer in. But you can not put say a motor From the 80s that was ADR 27a 27b or 27c in :)
h0Ld3n`VN
NO CAR ATM.. -.-
thankss jasonn big help :)
tadpol88
vr ute
thats me:p
pillzor
VS executive
whats the benefit of an rb30 over a 3.8 ? , just curious.
Vee-ard
QuickVR95II 2010 Survivor
Bayswater, WA.
Foam Tuned VR 5.0l Ute
the japanese 3.0 is pretty tough, but I would only do it with the turbo as well, I dont see the point if its NA unless you're a real fan of the motor.
VN_Luke
ƃuoɹʍ ʇsnɾ sı sıɥʇ
Mexico
Get in the ute
It's a tested and proven motor that can make & handle decent power without heaps of money spent. - plus there is great aftermarket support and plenty of off the shelf go-fast bits available.
pillzor
VS executive
i would have said the same thing about the buick though.
VN_Luke
ƃuoɹʍ ʇsnɾ sı sıɥʇ
Mexico
Get in the ute
:p
how many 10 sec/300kw+ rb30 powered VL's are there?
and how many 10sec/300kw+ buick v6 powered VN+?
The v6 development is getting there, though - it seems to have come alive a little bit in the last few years.
