NtHL94
- Sep 14, 2020
- 23
- 2
- 3
- Age
- 29
- Location
- Melbourne
- Holden Commodore Rb30, Also have SSV VE
Hi there, first post on the forum
Having Some Issues with my Rb30,
Cranks and rotates but wont start ;
-REPLACED ALL SIX INJECTORS+PIGTAILS+SEALS+CONNECTORS,
RAIL IS RECEIVING FUEL AND PUMP PRIMES NICELY
-USED NOID LIGHT AND INJECTORS ARE RECIEVING SIGNAL
-MAF
-ECU
-PLUGS
-FUEL FILTER+REG
-ALTERNATOR
-PLUG LEADS+ ALL TESTED AND RECIVING SPARK TO ALL SIX
-DIZZY+ROTOR+CAP+CAS
-IGNITION MODULE+COIL PACK
-TEMP SENS
-TPS
-NEUTRAL SWITCH+CLEANED UP SPEED SENSOR
-BATTERY+TERMINALS+REPLACED LEADS WHERE NEEDED+CHECKED ALL GROUNDS
-REMOVED HEAD AND REPLACED ALL SEALS/HEAD-GASKET+ RE SEATED+(LAPPED) ALL VALVES-INTAKE AND EXHAUST SIDES
Only thing i can think of, the reason i started doing replacing, was because of its really rough idle and really hard to start,
Tried to start after i replaced the injectors, and never started again.
-MAF
-ECU
-PLUGS
-FUEL FILTER+REG
-ALTERNATOR
-TEMP SENS
-TPS
