rb30 vk conversion
Cal-a
wicked sick
in Warburton, victoria
1986 vl executive, 88 vl executive
Hey all I'm currently doing a rb30 conversion into my vk I alredy have engine and gear box in all fine except for tue transmision mount doesn't line up its a 5 speed gear box just wondering if anyone has done this and if anyone can help
vk3800
Coffs Harbour NSW
BT50............ while the vk is rebuilt
What sort of 5 speed is it?
If its the same as a VL it should bolt up with the VL gear box mount.
Did you use the VL engine frame?
VK SL 3800
VK SL 5spd
^^ same as above. it all should go together the same as a VL, using all the VL mounts and crossmembers. What gearbox crossmember are you using?
VBRED
Melbourne - SE
Black VK Calais 333 Pack
From memory the VL floor pan is different the rail is higher on the left hand side then the right hand side to accommodate the cat. You can use your existing gearbox x member and weld a short length of angle to it. Drill holes to line up with the existing holes in the chasis and use a T400 auto gearbox mount or get a x member already made up by CRS and use a T400 auto mount.
VK SL 3800
VK SL 5spd
Really?, i didnt realise they changed the VL. oh well disregard my ramblings :p
VBRED
Melbourne - SE
I am positive. My son and I converted his VH to a RB30turbo 5 speed. It is a weapon.
njh1964
VK Calais
Hi VBRED,
I've posted a question on the forum, but perhaps you can help. How/where did you locate the catalytic converter in your VH RB30 conversion?
Regards,
Nick
