re- refilling VN air conditioning
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by Sons1vn2nv, Aug 29, 2006.
  1. Sons1vn2nv
    Sons1vn2nv Guest
    Has anyone heard of this before? I wanted to get my air conditionung tank thing filled as it has no refridgerant stuff in it, or is low, so ive been told, as i thought it wasnt as cool as it should be, but i was also told that i would have to go so a specialist and spend a coupla hundred on getting the fittings chaged over first cos since the 1990's theyve changed to eco friendly fittings...on the actual tank thingy...does this seem right?
  2. Spike79
    Spike79 Just Confused!
    Brisbane N/W Ferny Hills
    VZ Adventra LX6, VP Berlina LX, Citroen C3
    That is correct, The refrigerant gas used in vehicles before the mid 90's is R12 which is a CFC Gas, bad for the environment, etc. You can't get R12 gas systems recharged, not legally anyway.
    Modern vehicles use R134A gas, CFC free. This gas is not compatible with R12 systems. Therefore some components of the aircon system need to be replaced proir to regassing the system.
  3. churnit
    churnit Cheap parts!
    Brisbane QLD
    Might vary from state to state but here in SA you can still get R12 recharges.
    There is an aircon guy at Smithfield that has stocks of R12 and he got the aircon in my old '83 hilux working. Im spewing because Iv'e shelled out to have 3 cars converted in the last few years, at $600, each not knowing there was still some R12 around.
  4. xcop5l
    xcop5l 4th year spanner spinner
    ol' geelong vic
    VN ex cop 5L
    when you get the a/c system converted or retrofited the following things have to be replaced:
    all the o-rings in the system
    some of the rubber hoses
    all of the fittings for filling
    the reciver dryer and any thing that is leaking
    as the r134a gas reacts with some of the rubber in the system
