Reading spark plugs - when to change
Ron Burgundy
NSW
VF II SS
Ac Delco plugs. Just pulled one to check the condition.
Car's done just under 50 000km
Original engine was replaced at 35 000 km.
1. Do these look like 50 000 or 15 000km plugs ? i.e. did Holden reuse original plugs on new motor.
2. What do they tell you about how the engine is running ?
3. Are they still good ? I.e. no need replace.
Would love to hear some thoughts :)
To me they look like original plugs and it appears there is some carbon buildup on them. i.e. running a bit rich.
However, they dont look like they need to be changed yet.
Ron Burgundy
NSW
VF II SS
Here they are...
gossie
Gold Coast.
VE International 3.6L
Look good to me.
Just gap them before they go back in.
shane_3800
35
places
vr commo
They have plenty left. Likely the originals. The little tip when it gets to the cone section well about 10 thou off thats when they're gone. Or when the earth strap starts to get eaten away when it's nice with a difined square shape its good. If the earth strap is worn the little bit of tungsten on the end will be gone.
3rspecB
VF2 SSv Redline, White Manual Sedan
The look good. All 8 of mine were similar to these, so I replaced them with stock plugs. 47.5k the car has travelled. My car is not stock though.
Ron Burgundy
NSW
VF II SS
Oh wow. They definitely look worn at 47 000km. Mine look very different which makes me think they might have come new with new engine
Big Red VF-SII Go-kart
I love puddles.
Darwin NT
VFII MY17 SV6 (LFX) Sportwagon (SOLD)
After prolonged, high speed travel the plugs will be greyish-white with minimal blackening of the thread base. The black looks to have a bit of luminance about it — is this oil??
Why are you replacing them?
The plugs also appear out-of-gap, but still serviceable. Scheduled replacement is around 140,000km,. I don't see why there should be excessive wear or misfire before then. If excessive wear is evident at 50k, you need to find out why before replacing them with new plugs.
Skylarking
123
Downunder
Commodore Motorsport Edition
@3rspecB, it is odd that your plugs are worn @ 47.5k kms yet the service life is 140k kms?
What was the reason you looked at the plugs so early in their life and what would be the cause of such an early demise?
@Ron Burgundy the following video may be of interest to you
Ron Burgundy
NSW
VF II SS
I just removed one to see if they are still good. Was not planning to change them per se.
No oil on them. Just some glossy carbon. Minimal.
The gap looked fine to me. It's meant to be 1mm anyway...
I love puddles.
Darwin NT
All good!
