07GTS
- Sep 8, 2013
- 4,998
- 6,671
- 113
- Location
- Australia
- VEGTS BUILT BLOWN E85
PD blowers have bypass system so ur not in boost until u use a desired MAP to when the vacuum holding the bypass open closes and then u make boost quickly from that point, camshaft is also a big changer of MAP so it al works together, on hwy cruse u should be about same as factory its just the getting to cruse that uses more as the rotors are always spinning even bypassed its easy airflow for the cylinders to suck in with light throttle, and u have alot of torque to use so its easy to get carried away in the moment.... for all out power go 2650 or not far behind is the 2300 either are too much for the street anyway
