aceventura
Doesn't drive like this
Just checking, are you driving a few hundred km to get these readings, do you do the maths when you fill up at the pump? It takes a fair bit of distance for in-car meters to read accurately. Even after a full tank mine is still often a litre or so off, and if I've only driven 10-20km it can be up to 10L off!
What exactly are you saying here?
In my experience the fuel consumption calculated by the trip computers is fairly reproducible - if the fuel consumption rate is higher than you expect, I think it is likely you are using more fuel than you expect. Driving 10-20 km from a cold start can use substantially more fuel than the next 20 km once the engine is hot. I am not what is happening in your circumstances, but I refuse to believe that the trip computer is that far out over small distances.
Regarding accuracy of the meters, it is just a matter of calibrating them. I calibrated mine and and if you cross check the amount of fuel added at the pump and what the trip computer thinks the car has used, the two numbers are within 100-200 mL everytime. This means that all the calculated fuel consumption rates are accurate to better than 1%.
My understanding is that the trip computer just counts injector pulses and converts that into the volume of fuel injected (using an appropriate calibration number). Hence, if the numbers still don't add up, I would guess you have a leaky or blocked injectors, or bad fuel pressure.
Please correct me if I am saying anything stupid
