Really Really Need Help
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by Mook05, Jan 13, 2008.
  1. Mook05
    Mook05 New Member
    VR S2 S PACK
    I have a VR S2 S pack which the other day done the fuel pump after i got it back from the mechanics it didnt seem to be driving properly so i pulled over turned car off then it wouldnt start again so they towed it back there n had a look. it was only a fuse.
    I drove it home and around with it blowin another fuse that night so i repleced it didnt drive the car untill the next day. i got about 20 kms done the road n it done it again except this time everytime i put a new one in and went to start the car it wold blow it strait away.
    The fuse it keeps blowing is the little engine fuse. so i was wondering if anyone had any ideas on what it may be and how to fix it. With out the car running i have no way on getting to work which i need so i can pay for it to get fixed.
    thanks
  2. hako
    hako Donating Member
    Toowoomba SE QLD
    VS11 BT1 V6
    It could be the oil pressure switch which I think runs thru the engine fuse - they can short internally and supply power to the fuel pump. I'd also be a bit sus that this is happening after a new fuel pump!!!!
  3. Chirpstr
    Chirpstr A new project attack
    VR Berlina M5, VP M5
    hako seems to be right about this...yeah I would check the wires at fuel pump maybe give the plugs a spray with elecy blue can CRC.
  4. DannyboyDS
    DannyboyDS Just hand me the pliers.
    VS Berlina
    i'd be calling the mechanics up and asking if they can take another quick look at thier work as after they touched it something went wrong, any good mechanic would be more then happy to double check thier work.
  5. silver_bullet
    silver_bullet Now Genesis Blue Bullet
    moura
    vr commodore S
    a tradie at work was tellin me he had exact same problem on his vs. he said he tested everything and found that the wires running to the oxygen sensor looked to be melted, pulled them apart an what do ya no, they were shorted. check this out cuz when u sit and idle it gets pretty hot in and around ur exhaust manifolds. hope this helps. its some sort of short mate, just keep pullin fuses and keep testing, u will find it. patience
  6. DannyboyDS
    VS Berlina
    you can also do a continuity test from the fuse in question to the car body to determine which end it is on, fuse to battery or fuse to component.
