rear badge aftermath
MAC-VN
vn90
this is what was left when i took the commodore badge off my boot
n i dnt no how to get it out ah other then respary or put badge back on
MikesCalais
Trust me, I'm a Doctor
VE Calais V International
MAC-VN
vn90
its like a werid colour paint
i cut n poilshed it with a poilsher n it didnt no one thing to it
Daniel.B
VP Exec S2 3.8
Have you removed all the glue residue completely, and that's whats left behind? or do you still have some residue on there. I removed all my badges and door moulds from my VP last week, and the rear badges are just held on by an adhesive, their not sikaflexed like the moulds, and just requires some firm rubbing with a dry rag, the reside from the glue will begin to bunch up and you can pull it off. A little Prepsol, or wax/grease remover, helped remove any real small areas once i was done. Did you damage your paint when removing the badges, how did you take them off??
davway
Warrnambool
WK LS1 Statesman
looks like unfaded paint where the badges were and the rest of the area is faded - is that correct?
dont really know what you could do for that, other than trying to polish the faded area.
if the paint is damaged though, you wont get it back to the same colour as under the badges.
you could maybe try some fine sand paper and try and dull down the paint under the badges to match the rest of the area.
Andrew426
New Plymouth, New Zealand
VP calais, VR Berlina, VJ valiant, BG5 legacy
It looks almost like the adhesive has stained your clear. Turtle wax scratch&swirl remover might be your go.
Kevin Paisley
Qld
Jalpa tt
Easy fix - cover it with a Commodore badge, will hardly notice it
