Rear brakes no longer working, need help to fix them
Callan Carpenter
Vy executive wagon
I've got a vy executive wagon 2003, I recently disabled the rear brakes at the master brake cylinder for certain reasons and I also put a bolt in just so I don't lose any fluid but when I reconnected them their still not working so I've got no handbrake and no rear brakes is there anyway I can fix this or do I have to replace the system?
Edit: the handbrake warning also comes up all the time while driving and it beeps all the time too.
lowandslow
NSW
V2 III Monaro
did you bleed the rear brakes once they were hooked up again?
greenacc
Searching for the billion
VE Berlina
They will definitely need bleeding after being disconnected so try it and see.
Why is handbrake not working did you disconnect that too?
How did you leave the brake lines while they were disconnected? If they were left open that won't help things.
Callan Carpenter
Vy executive wagon
They were left open, would I need new handbrake lines and would that fix that issue? Or could I get away with cleaning them somehow?
I'll double check to be 100% sure if it's working or not by putting it In neutral and trying to push the car with the hand brake on and see if it'll move or not.
Edit: just checked to see if handbrake works and it does, i should aslomention that when i put my foot on the brake pedal it goes a bit more then halfway down till I feel something happen would that be cause the brakes need to be blesded?
greenacc
VE Berlina
The fluid in the open lines would have absorb some moisture. Hopefully not enough to cause damage like rusted calliper pistons.
A good brake fluid flush and bleed would be the first thing to do to get fresh fluid in there.
Callan Carpenter
Vy executive wagon
They where only left open for maybe 5 minutes at most they I put everything back to normal so hopefully all the system needs is a flush then
greenacc
VE Berlina
Oh 5 minutes isn't really a problem. It sounded like you were driving around with the rears disconnected for some time.
See how the flush and bleed goes.
Callan Carpenter
Vy executive wagon
Nah as soon as I was done I connected it back up and then the rears just didn't come back, I've only driven to work without the rears today but it's was all connected for that drive and I was expecting them to come good after a bit of fluid pumping into the brakes but it didn't to my surprise, I hope doing that wouldn't make it worse for the car though.
I'll do the flush as soon as I get home and I'll let you know how things go.
losh1971
North Tas
VE Series I SS Ute
Probably air in the lines and possibly in the ABS pump.
