Rear Brembo Upgrade
Discussion in 'VF Holden Commodore (2013 - 2017)' started by SCM071, Jul 27, 2014.
  1. Bhp Steel
    Bhp Steel Banned
    south coast
    holden
    On E-Bay from "Yorkim_Car_Parts" in the USA you can buy "3d Red Brembo Style Universal Disk Brake Caliper Covers" 4 pieces front and rear for US $17......cheap as chips for your show pony.....all you have to do is measure up your calipers for your vehicle...and send the dimensions....they are heat resistant and are glued on....see the web site!
  2. vl_nick
    vl_nick Member
    VL Wagon, VF Redline
    May as well order your big 4" cannon exhaust tip whilst you are at it.
  3. lmoengnr
    lmoengnr Well-Known Member
    Sunbury Vic.
    MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
    Good point! Just drilling would leave a few 'stress raisers' in the hole.
    Would be better to drill slightly undersize, then ream to size, finally de-burr the holes...
  4. Brettv
    Brettv New Member
    VF SS Ute
    And then tap I assume? I'll check the holes tonight, cant remember exactly how much meat they have around them. Other option is to use M12 bolts and a sleeve in the axle hole.
  5. lmoengnr
    Sunbury Vic.
    No, the bolts screw into the caliper.
  6. Brettv
    Brettv New Member
    VF SS Ute
    Correct, im talking about the need to drill and tap the caliper to accept the larger bolt. the axle size is ok as is.
  7. Brettv
    Brettv New Member
    VF SS Ute
    Hi All,
    A quick update, I've had the front calipers drilled and tapped and they now fit perfectly. However, The stock SS 18inch wheels dont clear the caliper. The circumference is ok, but the front part of the caliper (the face you can see when looking straight on to the wheel) rubs on the inside of the wheel.
    So looks like ill go for a set of redline 19inch wheels.
    -Brett
  8. Brad Baker
    Brad Baker New Member
    VE SSV Ute 6.0L
  9. 426Cuda
    426Cuda SUBLIME!
    Wagga Wagga
    VF Redline Sedan - A6 Spitfire MSE...
    Hi,
    I bought them over the counter at my local Holden dealer.
  10. 426Cuda
    426Cuda SUBLIME!
    Wagga Wagga
    From memory, I think they were the same as the standard front bolts for Brembo's. I have a set of new geniune HSV backing plates if your interested?
  11. Brad Baker
    VE SSV Ute 6.0L
    Thanks for the info. I must be asking the wrong questions. Cheers
  12. SSVREDLINE2014
    SSVREDLINE2014 Active Member
    Illawarra
    VF SSV Redline
    Anyone know who has the cheapest complete package for the rear upgrade? Looking at the grey calipers...
  13. 426Cuda
    426Cuda SUBLIME!
    Wagga Wagga
    Amazon was good to me for calipers. Less than $200 AUD. Then pick your preferred rotors and pads. Other stuff e.g bolts from holden. All up for me, fitted with T3 4000 rotors, good quality pads and braided lines on all 4 corners was about $1k. Best brakes I've ever had! Just awesome. Great upgrade
    SnowDoggyDogg likes this.
  14. SSVREDLINE2014
    Illawarra
    VF SSV Redline
    Those brakes are the cadillac ones right?
  15. 426Cuda
    426Cuda SUBLIME!
    Wagga Wagga
    Yeah mate. There are part numbers for these and the bolts floatin around on here somewhere.
  16. 426Cuda
    426Cuda SUBLIME!
    Wagga Wagga
    Here's a couple of pics of how they end up: 20170424_204609.jpg received_1141106022702419.jpeg
    3rspecB likes this.
  17. SSVREDLINE2014
    Illawarra
    VF SSV Redline
  18. 426Cuda
    426Cuda SUBLIME!
    Wagga Wagga
    They came blank. Just bought the decals off ebay.
  19. RED LION
    RED LION Active Member
    SA
    VFII Redline
    Nice.
    I'm hoping to upgrade the Calais with these after I get wheels.
    I've been looking around to see what I'll be looking at price wise and it really does vary. Looking at a full ront and rear set for 2k to nearly 3k.
    I would like the updated rotors though, they really do look good.
  20. SnowDoggyDogg
    SnowDoggyDogg 2ltr? = Only milk & juice
    Goldie
    Gen F GTS
    Red you can put them together for much cheaper than that by checking out Amazon and ebay USA.
    426Cuda likes this.
