Rear Brembo Upgrade
Bhp Steel
Banned
south coast
holden
Hey Guys,
I have a VF SS with the factory 18inch alloys. Does anyone know if the brembos would fit? (front and rear) Was thinking of getting the upgrade ebay style, eg VE VF HSV GXP Redline Rear Brembo Brake Upgrade INC Calipers Discs AND Pads | eBay
Cheers,
Brett
On E-Bay from "Yorkim_Car_Parts" in the USA you can buy "3d Red Brembo Style Universal Disk Brake Caliper Covers" 4 pieces front and rear for US $17......cheap as chips for your show pony.....all you have to do is measure up your calipers for your vehicle...and send the dimensions....they are heat resistant and are glued on....see the web site!
vl_nick
VL Wagon, VF Redline
View attachment 176281View attachment 176280
May as well order your big 4" cannon exhaust tip whilst you are at it.
lmoengnr
Donating Member
Sunbury Vic.
MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
What's your opinion, does this make you feel funny? or do you think it would be safe?
Good point! Just drilling would leave a few 'stress raisers' in the hole.
Would be better to drill slightly undersize, then ream to size, finally de-burr the holes...
Brettv
39
VF SS Ute
And then tap I assume? I'll check the holes tonight, cant remember exactly how much meat they have around them. Other option is to use M12 bolts and a sleeve in the axle hole.
lmoengnr
Donating Member
Sunbury Vic.
No, the bolts screw into the caliper.
Brettv
39
VF SS Ute
Correct, im talking about the need to drill and tap the caliper to accept the larger bolt. the axle size is ok as is.
Brettv
39
VF SS Ute
Hi All,
A quick update, I've had the front calipers drilled and tapped and they now fit perfectly. However, The stock SS 18inch wheels dont clear the caliper. The circumference is ok, but the front part of the caliper (the face you can see when looking straight on to the wheel) rubs on the inside of the wheel.
So looks like ill go for a set of redline 19inch wheels.
-Brett
Brad Baker
42
VE SSV Ute 6.0L
Blokes,
Yes you will need to buy a different set of caliper bolts for the rear. GM part # is 92139080. Cost is $31.40 inc GST.
I just have been reading up of the forum. I have rung a holden dealers and they quoting me $29 ea bolt. Just wondering if you still had the same contact whem you purchased your bolts?
Thanks
426Cuda
SUBLIME!
Wagga Wagga
VF Redline Sedan - A6 Spitfire MSE...
Hi,
I bought them over the counter at my local Holden dealer.
426Cuda
SUBLIME!
Wagga Wagga
Hi,
From memory, I think they were the same as the standard front bolts for Brembo's. I have a set of new geniune HSV backing plates if your interested?
