Well reporting back after service visit today.
When I dropped the car they asked me to wait for the Holden Foreman to go for a drive with me. He noticed the sound straight away.
He showed me from what I could work out was a tech line report which advised to change the gear oil.
He said that the oil is hard to find at the moment as it’s expensive and replaces the standard oil in the diff.
Picked it up this arvo and seems good as new. I will test things out over the weekend to ensure it’s sorted...
I think I am having the same issue, started to hear a noise a week or so ago, took to local mechanic thinking it might be a wheel bearing but there was no play in the wheel and they couldnt hear the noise.
i have since learnt the noise gets worseas it warms up or longer trips.
what dealer in wagga did you use as I am only 70km down the road ??
Hey mate, I had a similar issue with my 2018 ZB v6 awd, started as a clunk and drumming noise in rear when feathereing the accelerator in low gear. Two Services done and they couldn't hear it??? Worse when cold! Problem got worse and cars now done 70000 kms and progressed to a rear end grinding noise with slipping gears also.Hi all....
So just had the 24,000km service and was able to duck away to Wagga Wagga for the Easter break.
So now that I’m back I have noticed a noise coming from the rear when I’m driving and turning right majority of the time.
Also if I’m feathering the accelerator pedal or reversing low speed.
I’m booked in tomorrow for it to be checked and hoping it’s not a major deal. Also hopefully the dealer will hear it as it seems to be the loudest on cold starts....
Anyone had this issue or had it fixed? Any advice or details I can share with dealer would be appreciated.
2019 ZB Commodore VXR.
Cheers... Tim
Thats what happened to mine right turns only louder going around roundabouts. replaced under warranty.nothing to do with the oil.its the electronics thats what holdens told me.must be a known issue as there was no discussion they came straight out and said will be replaced under warranty. That was at 28000 km.Hi all....
Cheers... Tim
