Steven01
- Aug 13, 2016
- 13
- 0
- 0
- Age
- 45
- Location
- Brisbane
- 2007 WM Caprice
Found out how to fix rear dvd entertainment. If a dvd disc is in the entertainment system and it wont eject or read but you can hear it spin it can be fixed.
Just take the entertainment dvd reader out. Is abit of a hard job and slow work as you need to also remove the interior lighting parts aswell. You need to disconnect both rear wire adapters at back of dvd reader. Once out look at the front where dvd goes in and you will see 2 small screws. Remove these screws and gently lift the plate up about half a centermeter. Now reconnect dvd and wires back in car with the plate lifted and press eject button. Dvd should come out. Disconnect and put 2 screws back in and reassemble and it should be working fine.
The reasons i found that dvd gets stuck are.
Dvd being used and battery goes flat.
Hard bang or sudden shock while dvd in use.
Hope this helps anyone.
