ok so my car has power windows and when the rears go down they make this loud scratching type noise, i havnt pulled the trim off yet so see what it could be, does this happen to anyone else and is there an easy way to fix it?
Make sure that there is no foreign material stuck in the gap between the door trim and glass, because the sound might be cause by some foreign material rubbing on the glass. Be sure to check the outside gap to.
Make sure the loom and anything else is not touching the cable. When I installed mine the cable was touching the wiring and making a scratching noise. Check out the cable cos it may be frayed as well.
