Rear shock issues
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by SKNOT9, Jun 15, 2008.
  1. SKNOT9
    SKNOT9 All hope is gone
    Lobethal, South Australia
    VS series II Acclaim
    Hi there. today i put some new fe2 shocks on the back of my irs VS. pretty simple procedure, not much i can do wrong. Once it was finished i noticed that my car was about 2 or 3 centimetres higher. How can shocks make a car higher, is there something else wrong? any help would be great
  2. joe joe
    joe joe New Member
    nup sounds right, in time it'll come down again
  3. Scooter79
    Scooter79 Well-Known Member
    South Coast, NSW
    VSII Calais supercharged
    This probably explains why my calais sits lower in the rear than when I first bought it. Just confirms my shocks are stuffed. Hey eddy, How much difference have you noticed in handling and ride quality just from changing the rears?
  4. hakhawk
    springs probably arent sitting in the spring seats properly.
  5. SKNOT9
    How much time. like weeks or years lol. and it actually rolls heaps less with just new rear shocks. i was quite surprised. specially since it looks like its jacked up.
  6. R0d
    R0d New Member
    cammed vu maloo r8
    lol all the shocks in my car were able to be pushed in and never expanded, and the springs were sagged so when i put all new ones in there the drive was heaps firmer. I think its a month before the shocks start to soften, my rears were high till i put my old tyres in the boot and now its lower
  7. SKNOT9
    Oh yeah, and some doochebag sold me fe2 rear springs off ebay claiming to be for vr-vy (which doesn't sound right as vt onwards has a different irs rear spring) ended up being vz ss ute springs. i emailed him to complain and he said that all the fe2 springs are the same. i gave him the benefit of the doubt and tried to install tham. sure enough they jacked the rear of my car by about 50mm . NOT HAPPY!! sorry bout my rant, had to complain to someone.
  8. hako
    hako Donating Member
    Toowoomba SE QLD
    VS11 BT1 V6
    Shocks for FE2 specifications are gas filled and they cannot can make a car sit higher - initially it may seem that way but it is purely an illusion. The only shocks that can alter a cars height are air shocks which need a compressor to alter the ride height.
  9. SKNOT9
    its definately not an illusion. measured it before and after 2-3 cm difference
  10. joe joe
    joe joe New Member
    lol, i actually don't know how long but i'd say few months. a car will only lift up from shocks if the old ones were pretty worned out.
  11. Not_An_Abba_Fan
    Not_An_Abba_Fan Exhaust Guru
    Bunbury, WA
    Strange Rover
    Only happens in IRS cars. Live axle cars it makes no difference, but new shocks in IRS cars does actually make it sit a bit higher.
  12. hako
    Toowoomba SE QLD
    VS11 BT1 V6
    I don't doubt your measurements - maybe measure again in a week or two as the theory is that gas filled shock should not make any difference. Maybe just jacking the car up and having the suspension hanging fully down while changing the shocks has caused this. If it stays that way you will have a higher centre of gravity which will (again in theory) make the car roll more on corners......
