fergi
- Oct 23, 2003
- 232
- 1
- 0
- Location
- HAMLET BRIDGE
- VP 5 LITRE V8
i want to install a cd deck in my vp,it has only the front 2 speakers ex factory ,when you have to cut the holes in the back of the car do you take out the carpet from in front of the rear window then draw out the template and cut from the top with a jig saw or do you go from inside the boot,there seems to be 2 wires with white plugs in the boot at the top where you would expect the speakers to connect ,i am wondering if these are the speaker wires in the standard loom .also is it much of a job to install your own cd player.auto barn here in adelaide want 180 dollars to do the whole fit, ie deck and two front speakers which i assume would fit into the existing holes as they are sony 10 cm and install rear speakers this seems like a fair bit if i can do it myself without all the usual hassles i wouls rather save the 180 dollars
cheers fergi
cheers fergi
