Rear Tyre Wear - SX6 Adventra
bumstein
'06 VZ Adventra
Hi folks!!
Looking for some ideas on how to fix the rear tyres from wearing the outer edge (yep, I've tried search function until I was ready to start self harming).
Adventra VZ '06 SX6. Chewing tyres like toffee, the last set have lasted about 5 months on the rear and the outer edge are once again cactus.
I have had it wheel aligned several times, and kept tyre pressures at recommended levels.
The problem seemed to start after or around the time I had some control arm bushes replaced on the front of the car, could this affect the back?
Anyone else with cross track get this problem?
Any ideas where to start will be appreciated :)
Thanks!!
Kiddo
You're serious bro?!
Mitsubishi Colt
Camber/toe could be out?
Benboy
Hill River, SA
2007 SVZ Wagon
Take the car to Wheel Alignment Specialist and they should be able to resolve the issues for you.
Faynt11
Feeder of Trolls
07' VE SV6 Ute
Sounds like positive camber.
bumstein
'06 VZ Adventra
Thanks for the replies!!
It shouldn't be a camber issue, nothing has changed there and it doesn't appear to have significant camber. Especially to wear the outside edge.
Toe in/out should be solved with wheel alignment?? Seeing as I've had a few of them even if they screwed the first one up surely a different place can't mess it up again right?
And a Wheel Alignment Specialist, I thought they were much the same. Is there a specific place I should find that are better geared up for it than other places? Know of any in WA?
Thanks for your help ppl!!
leethal1
Perth Australia
2005 Adventra LX6, HG monaro
I had mine done at tyre power in kelmscott after i had my suspension bushes replaced (i had the front control arms done when i purchased the car). they seemed pretty honest, they checked and adjusted 3 out of 4 wheels. take it in to a shop and ask for all 4 wheels to be done and get the report
